Who's good at reading spark plugs?
LaRea
Member, Moderator Posts: 7,974 mod
Anybody want to offer opinions on what these spark plugs say about the health of my engines? @212rowboat, @69fastback ?
2007 Rinker 370
Merc 496 engines with 800 hours
Plugs have 300 hours
[EDIT: plugs are AC Delco 41-983, platinum plugs]
After replacing plugs and wires this weekend, I noticed an immediate bump in performance. Cruise MPG improved by about 9%, getting back up to what I recall seeing a few years ago. I attribute the improvement to the wires, not the plugs. The wires were probably original, and two wires had severe chafing damage.
A few things I noticed about the plugs:
2007 Rinker 370
- S8 is cleaner than the others. That's one of the plugs with a damaged wire. It's possible the plug was not sparking at all.
- S4 is a little bit shiny. Oil fouling?
- P3 has some crusty buildup on the side of the insulator.
- P7 has corrosion on the outside ... maybe a water leak that I need to investigate.
Post edited by LaRea on
My speciality is 2 cycle so I only worry about grey plugs(lean) i want charcoal wet ground straps. No valves or oil rings to worry about.
Ill also be following this thread closely.
How do the efi motors do at idle/trolling speeds vs carbed? Even with my Holley dialed in by one of the best in the carb industry i still needed some wot after long idle times to clean the plugs.
I did the plugs when I got the boat from someone who probably couldn't spell maintinince and they looked all normal and matched.
Did it have a probe in the intake or engine mount fuel filter assembly? Usually they have some place to heat fuel or air when operating at or near freezing temps
A guy picks them up for food or maybe bait. Once they warm up they come to life and go ape $hit all in this guys car and causes him to wreck.
500 hrs on a set of plugs sounds about right on new efficient efi motors. 300 wouldn't hurt.
Florida ain’t the paradise Floridians want it to be...
