280 EC - No shore power
Out of the blue, shore power stopped working in the starboard plug :s  Tried the portside plug as well - same result. Tried different outlet on the shore power stand - same result. Checked all breakers - nothing seems off. No voltage or green light in the cabin switch panel. Checked under the aft seating are - set to on.
Any ideas? Is there a breaker for the starboard side somewhere else, maybe engine compartment or hidden away?
    edited August 2020
    Is that shore power stand broken,maybe all outlets don't work? Try a different cord maybe. I'm assuming this isn't your first time plugging in so you checked all the breakers in the main panel, maybe try and reset there breaker (turn off then on) it may have tripped but not noticable and resetting it may do the trick.
  • PhilipPhilip Member Posts: 25 ✭
    Thanks @Aqua_Aura - I'll try a new cable tomorrow, and another stand.
    There is a breaker under the cup holder at the rear U shaped seat that is for the starboard shore power connection. Make sure that they are in the on position. The breaker is covered with a white outlet cover and is rather nondescript.
    I totally forgot about that breaker under there. 👍
  • YYZRCYYZRC Member Posts: 5,506 ✭✭✭✭✭
    Borrow someone’s working shore power cord to eliminate yours as being the issue?
    I was all alone today at the docks - but I’ll borrow one tomorrow @YYZRC
