Faria dual engine guage set for sale
Have a set of guages for sale if anyone wants them. I was thinking $100 plus shipping for the set. I also have the syncronizer that isnt pictured. Only used for one year.
The second type is an hour meter which reads square wave pulses from the motors alternator or ECM module. I am concentrating on a Tachometer with Hour meter built in. (I have a Faria Euro 7000 rpm Tachometer with hour meter) This type of instrument reads the pulses in a square wave form and shows the rpm of the motor. The hour meter also reads these pulses and only runs when the motor is running.
Here is the dilemma. How do I add hours to this type of hour meter without running the motor? Well the answer is, you need an external Square Waive Pulse generator. I found one, it is a TOOGOO Square Wave Signal Generator NE555 Pulse module. This module runs from 5-15 volts DC. Cost was $3.25 with free shipping on Amazon.com. Other vendors sell this item.
Here is the hookup that works for me. There is a little rectangular box with three screws in it. One is VCC, GRND, OUT. VCC is the Positive + Terminal, GRD is the Negative - (ground) terminal, and OUT is the Signal out terminal. I connected a red wire to the VCC, Black to GRD, and Green to OUT. I clipped the Red wire to the Positive 12V of the battery and the Black to a common ground -. The Green I connected to the SIG post of the Tachometer. I connected a jumper to the Positive + of the Tachometer also. This powered up the instruments with having the motor on. The TOOGOO Square Wave Signal Generator NE555 Pulse module has a jumper on it to change the frequency of the pulses. I found that the second set of posts from the right, if looking down from the top, with the wire block on the bottom, produces a pulse which read 1000 RPM on the Tachometer and the little hour glass, which shows the hour meter is working, is spinning. My old hour meter read 102.5 hours, so I let it run for that time and did not need to run the motor. I have not had any problems with this setup. If anyone else has a better suggestion let us know." Other people posted that they did it by hooking up a 9 volt battery. The whole post can be found here https://www.thehulltruth.com/boating-forum/684623-adding-hours-hour-meter.html
