Joker Valve
John41John41 Member Posts: 115 ✭✭
So I’m getting bad water coming back into my toilet bowl. I’m guessing I need to change the joker valve. I have a 342. Where would I find the joker valve on the bowl and does anyone know the part number for a new one? Thanks
    Do you have a hand pump toilet? If so, it is where the pump meets the base of the toilet and the hose is connected.
  • John41John41 Member Posts: 115 ✭✭
    No it’s electric not the hand pump
  • Dream_InnDream_Inn Member, Moderator Posts: 7,945 mod
    It will be where the waste hose connects to the toilet.
  • Pat310Pat310 Member Posts: 605 ✭✭✭
    Remove the three screws and it’s right there on mine. A Jabsco 37245 Quiet Flush.
    I bought the service kit on Amazon which include seals for the motor assembly because had a leaking o-ring.  Not a bad idea to do it all while you have it apart.
     Jabsco Service Kit (37045/245) 90197-0000, Service Kit (37045/245), https://www.amazon.com/dp/B007I8YFH6/ref=cm_sw_r_cp_tai_B99sFbHT36C3K
    edited August 2020
    Remember to have a Joker Party after you change it. Our finger mates had a horrible smell, after fixing it with a new joker they had a heII of a party to celebrate!!
