Dexcool and mercruiser antifreeze compatibility?
PickleRickPickleRick Member Posts: 4,131 ✭✭✭✭✭
I don't have many marine shops local, none i can go to without taking a 2 hr lunch break anyway.
Its near the end of the season so im stocking up on service items that may have been neglected in past.
First up is draining the closed loop system and flusing with fresh.
While I will be able to get most of the coolant out, I won't be able to get it all.
I plan to switch to dexcool as i heard it was compatible with the current mercrusier coolant that has been used.  Can anyone else confirm this?  I dont want to rely on googled results from a few other forums.  If it won't, what other coolant is compatible with mercrusier coolant?
