Winterizing AC
For my old boat, I left winterizing to the marina. Last year I stored indoors and heated so no issue. This year the old girl is going to get chilly.
I am going to tackle the water system and AC winterizing myself. I remember reading about someone adding a tee at the AC thru hull to draw in antifreeze. Could someone please point me to the tee that I need? Thanks!
First I flush it with a regular water hose... to get the salt out... then it's easy to see when it changes from clear to pink coming out of the bottom of the boat..
This is what I do, but I use a small bilge pump to force it through.
New pump, new strainer, new fittings, new hose.
Mounted all on a 1/4" thick starboard.
Hose goes from thru hull ball valve to fitting at pump. Added a garden hose connection with cap, then filter then pump then to A/C.
Close the thru hull ball valve, attach garden hose to fitting on pump, put other end of hose in bucket of anti-freeze, turn on A/C, when bucket is empty, done.
