2000 270 FIESTA VEE HELP
Jarodjay
Member Posts: 29 ✭
WE ARE NEW BOAT OWNERS AND ARE LOVING OUR BOAT. A FEW QUESTIONS (I DID SEARCH THIS FORUM FIRST BUT I AM NEEDING SOME CLARIFICATION). OUR BOAT DID NOT COME WITH A COCKPIT TABLE. IT DOES HAVE THE ROUND OPENING IN THE ENGINE HATCH. CAN AN OEM TABLE AND MOUNT BE PURCHASED THAT WILL FIT IN THAT SPACE? ALSO, WHAT COOLER FITS INTO THE STARBOARD SIDE? I READ IT IS AN IGLOO 25QRT. IS THAT CORRECT? DO ALL IGLOO 25QRT COOLERS FIT? THE REASON I ASK IS BECAUSE THE ONES I HAVE SEEN ONLINE LOOK LIKE THE SLOT IN THE HANDLE IS TOO LARGE TO HOLD THE COOLER SNUG. THANK YOU FOR ANY AND ALL HELP! WE TRULY APPRECIATE IT.
i use a soft side from walmart fits and works
https://www.walmart.com/ip/Ozark-Trail-Premium-Jumbo-Tote-Cooler/52620406
welcome = where do you boat
we hava 270 great boat
https://www.greatlakesskipper.com/oem-parts-and-accessories/rinker-boats
great boat
Anyway, on the subject of the cooler, don't sweat it, you're not missing much. When we got our boat 4 years ago I searched high and low until I found a new original. I'm just weird that way, wanted it all original. But I have to tell you we've only used it a handful of times. The cooler is junk, we all laughingly refer to it as the "ice melter". It's ok to keepd lunch cold for a couple of hours, but that's about it.
Instead we typically fill the space with either our beach bag, or another small cooler about the same size but better quality. It doesn't slide into the little retaining "bumps" like the original, but unless really rough water it stays in place. If we do keep the boat I'll likely do what other's have done and rig up some doors for more storage, or I've even had thoughts of expanding the cutout and putting a second small fridge in the space.
Anyway, there are several of us on here that have that model 99-01 270 and even the later models didn't change much so if any other issues feel free to ask for help.
Cheers!
I am gonna get a longer pin with a much better grab handle. Pulling that thing was not easy. I have considered removing the bolt that allows some adjustments so I don't have to worry about it should it happen again.
