Shower cubicle leak 280ec
Every time we use the shower we end up with wet carpet all along the front edge of the cubicle. I've checked the usual things: forward bilge dry, no leaks from shower sump, pump, or associated pipework. I notice that the front of the cubicle appears to be a separate part attached to the rest of the cubicle and there is a joint all along the front edge of the cubicle, below the door and just above the drain hole. Could that joint be leaking? Has anyone had a problem with that? Or does anyone have any other suggestions where I should start to look for cause of the leak?
Nick Wight.
Nick Wight.
