350 mag mpi backfire at WOT
gherkin
Member Posts: 45 ✭
Hi all. Just got my newly rebuilt 350 mag mpi back in the boat, it’s a 2000 270 FV. The engine is mostly running great. But it seems to take longer to get up on plane. I thought it was just me but after a few hours of running it in I tried a quick WOT run. It backfired at WOT and only got to around 4200 rpm. Pull the throttle back just a little and it clears right up and runs great. I think this is related to the slow planing now. Does this sound like a lack of fuel issue? Almost everything is new on this thing. Plugs, wires, cap, rotor, distributor pickup, coil, fuel pump, regulator, injectors, filters, and anti siphon valve is temporarily removed. Timing set to 8 BTDC. Fuel pressure jumps to 32 when key is turned on and maintains 25 when running. From what I’ve read that fuel pressure is correct. Fuel in the tank is from the beginning of summer. Im gonna keep running it out and then get some fresh fuel. But I doubt that is the problem. Any other thoughts on how to diagnose this. This is tough because virtually everything is new so I’m not sure where to go. Any help is appreciated.
You've an obstruction or a weak pump. Maybe its electrical and you don't have a great connection anymore, and the lack of juice to the pump causes it to struggle.... an obstruction could be a dirty filter with ease... and that could very well be because ots wet (water, not fuel) and swelled the filter medium.
Another just as likely issue is timing chain slop... the cam is clocked with the crank, and the dizzy is driven by the teeth on the cams nose... even a little slop causes issues.. the chain stretches, and it throws off timing. You say 8* but you should be at 10-12* without advance. To set base timing you have to shunt the ignition... dumbest of dumb questions: did you release the shunt after checking timing?
For certain: you dont want to lean out to the point you get backfire, which in that condition is certainly predetonation too... and can kill an engine... stay off WOT until you figure this out!!!
All said, my money is on the filter... if not that, I'd be pulling the dizzy cap and checking for slop in the timing chain.
Chains stretch after initial use when the little nylon ring thingies installed to make them "quiet" compress... which is why I refuse to use a chain so equipped, but which also means I have to go out of my way to find them.
