Knocking Noise
aero3113
Member Posts: 9,623 ✭✭✭✭✭
The last two times out I heard an inconsistent knocking noise (I think from starboard side). It starts about 2-3 minutes after up on plane (not at idle) and only happens after the first run of the day. It will go away about 10 minutes into the run I think. On the way back to the dock later in the day no noise. It happened Thursday night also, but yesterday afternoon when we headed back, no noise. It seems like if the boat sits for a few days it will happen. I’m thinking gimbal bearing or u-joints, what do you guys think?
Had the boat even taken an hour away to the dealer, totally stumped.
Mid summer I figured it out ~ I had a new Bimini made over the winter, it would lift a bit at speed & thump the support posts in their sockets. Pfffffff.
might have a pooberg in there.
Port
Oh I read that again I see you said it seems to be surface and doesn't have any play in it
Good point Al you must be a boat mechanic.
From what I've read clutch cone replacement is a common repair on the bravos.
