Attaching a 496 to an engine stand
LaReaLaRea Member, Moderator Posts: 7,974 mod
Anybody happen to know the bolt size for attaching a 496 to an engine stand?
I haven't pulled the engines yet, so I'm looking for a sanity check.  I think the right answer is:
Zinc plated class 10.9 steel, 10mm x 1.5mm, length 90 mm
I assume I'll use the bolt holes for the flywheel cover, which are M10 30 mm long.  The stand brackets are 60 mm deep, so I'd need 90 mm long.  I'm assuming it's a coarse thread, so 1.5mm pitch.
