water heater replacement options for 312
Hi I am a proud new owner of 2003 312. It needs a water. Attwood 93757 is no longer available. Does anyone have a alternative number.
Thanks
Thanks
I am considering ditching the one i currently have with a tankless 110. Ill have to run the genny to shower and it's only going to raise temps by 20 or so degrees. That's fine as all summer long the air and water temps are 85 plus highs and 70 plus low. These are not ignition protected so not got gas powered boats. I'm diesel so I don't think i have much of anything ignition protected.
Many times old holes are stripped or are prone to strip so new hardware and fresh holes are usually good thing so it gets a good bite. If the holes do align id probably use one size up diameter up screws for added bite. Don't want that heavy tank bouncing free!!
I dont think the swap is hard but these little guys are deceivingly heavy
https://cemarine.com/products/atwood-ehm6-ehm6-sm-electric-water-heater-w-heat-exchanger-6gal-110v-93891
On the 310 its is behind port side wall in the mid-cabin
