2005 270 Fiesta Vee Engine Vent fixings
Hi
Would anyone be able to post a picture of the outside of their engine compartment vents, two each side of the boat. Mine could do with the plastic fittings replacing, and I am not sure if they should have covers or grilles.
many thanks
many thanks
Rinker 270 instagram diary : sea_dream
A lot of guys here have used these because the hose clips on without clamps. Saves having to try to get hose attached from under the gunnels. Pull the hose out thru the hole, attach hose to vent and install vent. On my to do list this winter
These are originals if you rather go that route
I am due to complete the purchase of the boat in the next couple of days and know there are a few things to tidy up. I am not due to go back down to see her for a few days so this is the best photo I have that shows what is currently there.
My very first boat, and I am on a steep learning curve, so hopefully will be fun tidying up all these small issues.
Out of interest one other thing mentioned was the lip around the top of the engine bay has no additional foam type seal. Hence as some water/spray might have come through particularly the flat part at the back under the rear bench there is a small amount of corrosion on some of the engine bolts and connections, and a small amount of water in the bilge. Has anyone added a additional seal to the lip.
Many thanks all.
I am in the process of completing the purchase in the next couple of days. I am not due to go see her for a few days so below is the best photo I have of the vents.
It is my first boat, so am on a steep learning curve, but hopefully it will be fun tidying up some of these fairly minor issues.
Out of interest has anyone added any additional foam type seal around the top of the engine bay lip? The surveyor suggested that some water/spray may have entered the engine bay, particularly via the flat part under the rear bench, as the lip only seals against the underside of the hatch. Some of the engine bolts and connectors have small amounts of corrosion, and there is a small amount of water in the bilge.
Many thanks all.
I am in the process of buying the boat which should be completed in the next couple of days. I am not due to see her again for a few days so this image is the best I have of the vents.
It will be my first boat so am on a steep learning curve, although hopefully it will be fun sorting out these fairly minor issues.
Also has anyone added any extra foam type seal around the top of the engine bay lip? The surveyor noticed that some of the engine bolts and connectors have small amounts of corrosion, and some water in the bilge, which he though might be due to water/spray getting in where the lip only seals against the underside of the hatch. Particularly via the flat section under the rear bench.
Many thanks all.
thanks for the replies.
Are you in Europe?
Tried to find the torque on that engine but I don't see it anywhere.
This quotes
Max. torque 615 Nm at 2,000 rpm
Tests conducted by Volvo Penta show that the D4-260 DP lives up to its promises. Two identical Nimbus 250 Nova R boats were taken for a test run – one fitted with a D4-260 DP and the other with a Volvo Penta 5.7GXi, a 320-horsepower five-liter V8 with a Duoprop drive.
The D4-260 diesel engine accelerated faster than the gasoline-driven V8. For up to 25 knots, the D4-260 was 1.5 seconds, or 15%, faster. Moreover, fuel consumption at cruise speed is about 30% lower for the D4-260 than for the 5.7GXi.
It's great having all that extra room as well, I have an 8.1 V8 so a 3.7 I4 would make tons more storage space down below.
I even hired a boat captain to help me learn to drive her. He tried to take her out of the slip and after one buck, he told me there was something wrong with my boat and left...
