fresh water tank 312
toolmaker312
Member Posts: 126 ✭✭
Good afternoon,
Is there a way to empty the water with out running the pump through the sinks? It needs to be drained for the pink stuff. And can anyone point out its location on a 2003 312?
Thanks
Thanks
My tank has a quick disconnect fitting the PO installed at the pick up elbow in the bottom front of tank. It sits forward facing under the cabin floor.
I ran the sink until it ran dry. I then lowerd the bow in the trailer and disconnected the hose. What little water remained ran out into the bilge to be shop vacuumed out.
I then ran my hose pick up into the pink stuff ran her til both sinks spit pink.
Then went to the hot water heater, I opened it to drain and closed back up.
I have quick disconnects on the hwh too so I looked a hose from cold in hose to cold out hose. I then ran the hot water at both sinks til it was pink.
I then connected the hot water heater back up and ran a gallon of pink into the hwh. I then drained it a second time in case any water was left from the first drain.
So no pink in my water holding tank.
Also, the “manual” is a serving suggestion, gives an idea only, not actually a manual. Water heater is starboard behind the cushion panel at the foot of the aft cabin near stairs. There’s a cubby there with an access hatch, drains into mid bilge.
I'm thinking about making a serviceable one using aquarium charcoal.
The smell lingers after a pump out....so every weekend just about.
