Double whammy to start the weekend!
Spending the weekend on the boat just for fun during a tropical storm. Last night at 11:30 the cabin feels warm and the air conditioning is making a weird noise. When it usually is just quiet making the same noise this time it's getting louder and louder and then clicks off. Investigate quickly and notice the circulation pump is not kicking on. It was one of the projects to address this weekend as it had been making some weird noise anyway, luckily I had already ordered one weeks ago and it was on the boat ready to go. Took about 20 minutes to swap that one in, button everything up, push the power for the AC and the same result.
Took the panel off of the control box for the AC where all the wires go into and noticed some kind of oily substance on the control board and wires in there. Okay time to abandon ship. It's only about 15 minutes to home so I hop in the car and about 30 seconds later realized the front tire is flat! Luckily had a tire inflator in the trunk and drove home White knuckles and went to bed. Add one more thing to the list for the weekend that's going to be nearly impossible to get fixed!
Just can't make this up. After the Storm passes if I go to the dock and the boat is completely gone out into the Atlantic it will not be a surprise at this rate!
Contacted the air conditioning company as I had just bought it in June. We'll see what they say. Happy weekend.
What brand ac do you have?
I've since removed the old pump and the old cord. If that's the case and it had nothing to do with the control box, why wouldn't it work with the new pump? that's weird.
Replaced with this. https://www.amazon.com/gp/product/B006YGLRBA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Good/bad?
Couple questions:
Is it needed for oil to be in the power line? Wtf.
So now I guess since there's oil where I tried to splice it and oil in the control box, specifically there was oil on the power lines TO the pump dripping down... can we assume that this caused whatever the failure is?
Ie. how does it run just fine if I plug the pump into a regular outlet... I'd think if there was a problem with the controller board it wouldn't run correctly...where it seems to be running normally...
- The fan will not do 3 speeds anymore, just 1.
This doesn't look normal..does it? Is that a popped capacitor?
Luckily for you the circulation pump is a very heavy duty pump designed specifically for continuous running so keeping it going all weekend shouldnt have any ill effects. When water temps hit 85 plus and air temps have a low of 80 plus it's not uncommon for my AC to run continuously nearly all night (9 to 10hrs) i had to install a themro resistor in order to force it to shut off before the lines freeze. The circulation pump keeps going but my compressor is kicked off until the line temps rise back above freezing.
This cycle repeated one to two nights a weekend every weekend all summer long.
So far so good...
Stay safe guys.
2. Tire is still not fixed. Getting anyone to look at your tire in the keys when a TS is approaching has proven to be impossible. Maybe tomorrow. Who knows. Have just had to pump it up each morning.
3. Sleeping on the boat during a TS was "fun" however it would have been a disaster if not for marina friends and great canal neighbors. Once again it proves this boat is just too much for me if I can't figure it out on my own. Going to be a bummer to let it go in the spring but I just don't see it lasting long term.
