Project: Folding steps for the engine room
LaRea
Member, Moderator Posts: 7,917 mod
My 370 engine room was built with a single U-shaped step bolted to the stringers. Today I replaced it with two folding steps mounted to the bulkhead -- a much better solution. It's safer and easier to use. If they are in the way, I can fold them up. And now I can reach into the bilge (which was not possible with the original step).
In the first photo (forgive the leaves and mess) you see the original step (this is aft looking forward). Normally, the fire extinguisher bottle is mounted to the bulkhead just forward of the step. The new steps are on either side of the fire extinguisher. Here's the product I used:
https://www.amazon.com/gp/product/B000G6JYNC
If you attempt this mod, double-check what's on the other side of the bulkhead (in case a screw pokes through).
Post edited by LaRea on
I used the new steps a lot yesterday. Much, much better.
I always liked the nonskid they put on top of the risers. Not.
'05 Rinker 360 Fiesta Vee
I used four very stout screws into the fiberglass ... #10, maybe #12 but I'm not certain. I'm 185 lbs on a good day, and if I bounce on the step it feels solid and safe.
Drill the right size pilot hole. Too big, the screw might pull out under load. Too small, the screw will bind and could shear off.
Might be a good idea to trim off the insulation under the mounting area. I didn't, so there's just a tiny little bit of give when under a heavy load.
Also, the top edge of the step is kinda sharp. It's great for traction, but about a month ago, I slammed my elbow - hard - right on the edge. Then there was much wailing and gnashing of teeth.
