Mercruiser Mag Mpi Horizon W/Bravo3
I'm still working on engine and outdrive. Can anyone tell me, If you have this motor, what your WOT RPM is and With what pitch prop? Mine is only getting 4200 RPM with a 24 Pitch prop. But I am getting 41+ MPH out of it. Just wondering what everyone else is running. The book says 4700 - 5000.
350 mag B3 2.2 drive and stock 22 pitch prop
496/bravo3
4700 ish
24p
42-45mph
what kind of load
hows your bottom
tap speedo
UPDATE: I just came in from installing new wires and found #5 cylinder wire was off. So that should account for the spitting and sputtering.
https://www.mercruiserparts/vesselview-mobile
If you have 350 MPI serial # 0M300000 and above it is smartcraft enabled.
If you decide to go ahead you will need to decide where to mount the module as you will need other harnesses. I am putting mine behind the icemaker and needed 15' and 20' cables with a junction box. I can supply part #s. It can be put in the engine compartment but you will still need extra parts that do not come with the module.
so
you hava 350mag ?
i think you should be turning a 22p
