Trim at lower speeds
The bow of my 212 Cuddy stays quite high at slower speeds. I'm usually on the Rideau river in Ottawa, and there are a lot of no wake zones at which point I can keep the boat level at about 10 km/h.
If I want to speed up, but keep the speed at around 15 - 20 km/h the bow stays up so high, I cannot safely see anything ahead of the boat.
Thoughts anyone?
Thoughts anyone?
Drive trimmed down, trim tabs all the way down ... that's all you can do.
My boat is big, long and heavy for a single prop. I used to have to run tabs down completely to track at idle speeds, now I keep them at a level running position thanks to a crusing speed list.
Another fix for some stern heavy boats is chain...lots of anchor chain in the front locker if you have one. It's more of a bandaid than fix.
Trim tabs would be the best fix but that transom shape isn't friendly to tabs
Another cheap item to try is a a hydrofoil. I put one on the week before I put on my hill marine big cow prop. I also have some 100 ft of chain. My top speed is 22mph so keeping my nose down was a bit of an issue with only 220hp.
