Cap and Rotor for 7.4 questions. New Guy
picturethispicturethis Member Posts: 103 ✭✭
Hey guys,  Im a new owner of a 00' 272 captiva , 7.4 bravo 3 with the thunderbolt ignition.    I noticed that the points under the cap are corroded pretty bad but the rotor looks good.
  Can I use an automotive cap or marine only?   which cap do you guys run?   any part numbers would be great
thanks
russ
I am a new boater with my first boat,  thats why some of my questions seem dumb
  • picturethispicturethis Member Posts: 103 ✭✭
    its a 7.4 Merc
    The smart move is to use marine parts.  With the year/serial number you should be able to get a mercury / quicksilver or interchange part number pretty easy.
    I don't think an automotive cap will fit the merc distributor.  I may be wrong, though.. I think you're kinda screwed to buy the marine dizzy cap no matter how you slice it.
    with what I have read, its better to use an automotive cap with brass points (they dont corrode) rather then a marine which typically are aluminum
     I dunno
    edited April 2014
    A marine cap is designed to prevent spark-over. If you see it happen at night in wet conditions your cap will look like it lights up. If you use an automotive cap in a marine application and get a spark over more than the cap will light up - it'll be you and your boat too....and the insurance company will thank you as they won't have to pay. Marine application - marine parts - particularly where gasoline (special hoses and O rings) ignition parts (caps, wires cpaacitors) and electrical parts (tinned battery cables, plastic/composite electrical boxes , multi stranded 110v wiring). I know, really - I know from experience $$$$$$$  they seem to "see us coming" and charge more for marine parts but all of the ignition/electrical stuff is well worth the price. imo :-) MT
     marine stuff it is
    thanks for the replies guys
    Better be safe then sorry :-?
  • raybo3raybo3 Administrator Posts: 5,573 admin
    IMO I always buy marine parts over auto parts. There is a reason they are marine. I once used a auto starter and it did not last a year. Big PITA. Marine parts are the way to go....................
    Especially any electrical parts, auto parts are not 'ignition protected'. There are far too many stories of fires/explosions/deaths from this to ever take a chance.
