Would you replace the starter motors?
LaRea
Member, Moderator Posts: 7,554 mod
While my engines are out of the boat, I have an easy opportunity to replace the starter motors. There's nothing wrong with them, but they are 14 years old. On a fresh-water boat, what would you do:
1) Replace with OEM starters, $435 per set
https://www.amazon.com/gp/product/B001HBURKO
2) Replace with aftermarket, $140 per set
https://www.amazon.com/gp/product/B00TPM7UTI
3) Do not mess with them
I've unfortunately had my engines out or moved too many times. My oil pans always look ok. I believe it's because I keep my bilge dry. I know you do too. That would have me believe the starters are probably doing ok too. If I hadn't had my water pump leak and get brackish water all over my pulleys, they wouldn't have needed painted either...
@Dream_Inn - yes, replacing them is part of my continuing quest to manufacture good luck!
They will haunt your brain - if you do nothing.
I'd replace with thesehttps://www.google.com/url?sa=t&source=web&rct=j&url=http://www.marineengine.com/boat-forum/showthread.php?420262-Gear-Reduction-Starter-Replacement-LM318-s&ved=2ahUKEwiQl6yar_jtAhWDmVkKHQF1DJcQFjAEegQICRAB&usg=AOvVaw2jKWyT1Umtvp-MZiA1iPY8&cshid=1609422887974
http://www.apimarine.com/marine-electrical/mercruiser-volvo-marine-power-50-863007a1-30433.html
The link i sent you was to the marine engine forum, guys that build motors(marine in particular) for a living and/or a hobby so they don't generally have the same OEM bias many marine shops (dealers) have, some shops refuse to use or recommend parts that are not oem despite occasionally aftermarket suppliers have a superior product. If those guys would prefer these starters over oem on their personal boats, that says a lot about the performance and quality. As someone who wenches for a living, i hate wrenching during boat time.
Rather than just tell you about them I figured it would be better to link you to a forum where they know more about these motors than anyone I know.
