Fixed/not fixed/FIXED!!: Leak where windshield frame attaches to hardtop / arch
LaRea
Member, Moderator Posts: 7,944 mod
[EDIT: Read down and you'll see that my first repair did not work, but a later repair did work.]
I sealed a leak at the aft end of the windshield frame, where it attaches to the hardtop. It's probably common, so I'll share.
Symptom: Rainwater collecting under the trashcan and ice maker.
Cause: Failed seal between the windshield frame and the hardtop.
Solution: Sealed with 3M marine clear sealant.
The windshield frame has a slot for attaching canvas hardware. I took out the trash can and used a towel to dry off the plastic tray under it. Then I poured a bottle of water into the slot. Sure enough, some of the water found its way into the boat. As I was cleaning out the slot with a cotton swab, I discovered that I could poke the swab right in through an unfilled screw hole (second photo).
I filled the end of the slot with 3M marine clear sealant. While I was at it, I touched up the seal between the frame and the hardtop. It seems to have worked, but I'll know for sure after it rains tonight.
Post edited by LaRea on
The side window has to slide forward, which means the curved windshield has to slide forward. I was able to do this by removing 4 of the 5 windshield screws, and CAREFULLY pulling the windshield forward.
With the track removed, you can see there's a gap in the fiberglass where they cut out a flat spot to attach the track. Any water that gets in at the top can enter through this gap.
And at the bottom, there's big fat gap that gives water a straight shot into the boat. I can't imagine why they didn't seal this entire area, but I attacked it with a tube of 4200.
This was a relatively easy repair. It took me about 3 hours for both sides. Since then, it has rained twice, and the area under the ice maker is 100% dry.
