What do you recommend for bottom and outdrive paint?
luvinlife
Member Posts: 501 ✭✭✭
Just looking ahead for a few months from now when I’m going to paint the bottom and outdrive on my FV 270 again. I’ve tried a number of different things over the years, but looking for suggestions on what is the best. I know there are some non-copper paints that you can use on both the fiberglass and the outdrive and I would be convenient, but I’m not necessarily committed to that. It currently has a copper based paint on the bottom and I sprayed the out drive. Looking to buy the paint soon. What are you using?
On the B3 outdrives, Primocon and Trilux. I recoat every spring.
On the hull, Micron CSC. However, I think they must have changed the formulation over the past few years. I used to go four years before recoating. Now I'm getting only two years before I have to get a mid-season hull cleaning.
I really hate that my 2859 has bottom paint.
I would keep the bottom paint 1" to 2" away from touching the drive, just to be 100% sure.
