Probably too late!
DonGargano
Member Posts: 60 ✭
Hi Folks, Was reading some articles to see if there is anything I need to do to the boat trailer, before taking out of winter storage. Obviously I'd check the levels in the wheel bearings. Is there anything else before I hit the highways? I've also read that I should have "blocked the trailer" while in storage. I suppose this means using jack stands to take some of the load off the suspension. Thanks
Bearings, tires & lights. Look for broken or missing suspension parts/bolts.
Tires & bearings first. Chk the date codes on the tires.....4 digits. Manufacturers stamp the week/year on the side. Over 5 years old is suspect. Grease or repack bearings.
Dielectric grease on all electrical connections.
Give the bunks a look while the boats off the trailer.
Don't be shy with the dielectric grease on all connections, also use some rust inhibitor on springs/shackles/coupler/frame. Spray on some Fluid Film or Rust Check or Boeshield.....or?
All of the above will pay dividends down the road. Keep it stored outta the weather if you can.
I just mainly use the dielectric grease as an anti corrosive. After years of snowmobile trailers & boat trailers.....snowmobile trailers take a pounding. Cold, melt, salt & brine solutions on roads, absolutely the worst of environments. I goop that stuff on all connections.
I'm happy to say that my stuff gets top buck at resale. Doesn't even compare to untreated trailers. Same goes for boat trailer.
I go nuts with spray on Rust Check - the frame/axles/shackles/springs/coupler. Then grease all electrical connections. The elec connections are far easier to work on down the road if need be.
Good vid by the way.
I obviously use too much di-grease - but never had an issue. Wipe off the excess.....usually on my pants.
Rust check is a great idea...thanks for that. So for my connectors pictures above, probably around the base of the pins, and around the 'joint' once the two pieces are connected. Likely shouldn't be going this far down on the launch ramp, but I guess I should grease the installed connector outlet too.
Basically, the grease just squeezes out of the way, assuming it has the right viscosity at the required temperature range.
He also says that "conductive" grease is actually a powder of conductive particles suspended in dielectric grease. He says it doesn't have much effect on connectors, and it can create problems when used with dissimilar metals.
https://www.w8ji.com/dielectric_grease_vs_conductive_grease.htm
