T.V. Installation - Rinker 260ec 2009
mareeniville
Member Posts: 34 ✭✭
I have just purchased a19 in' dc tv and before I install it I was wondering if anyone has had problems with where they mount the unit on that door. Is all the wiring to do this install,is it in behind there somewhere ? Also in the engine compartment is there wires for an easy installation their too? Thank you for the help
I have a 2011 260EC. All the wiring is in the cabinet behind the head in the cabin. The pizza dish antenna is connected by cable to a signal amplifier (black box) which is inside this cabinet, just pop the door on the side of the cabinet (side facing bow). The cable from the TV needs to plug into this black box. My TV is mounted directly onto the door, with an appropriate backing/securing device.
As far as the second TV is installed, I don't think there's anything run as far back as the engine compartment. There might be a cable next to the aircon in the aft cabin, as I believe it is an option to install a TV where that cavity to the right of the AC is.
Have fun.
