Has anyone installed LED navigation lights?
Has anyone installed LED navigation lights on the bow? I'm thinking about it, but wasn't sure who had good luck with them. I know they have replacement bulbs, but the outlets are pretty corroded, so I want to change the entire outlets.
  • golfdoggolfdog ✭✭✭
    PairADice, I replaced the port and starboard lights on my bow, the anchor light on my radar arch, andthe transom light with LEDs 3 or 4 years ago. I replaced the entire fixture for all of them. I have had no problems with them.
  • thanks Golfdog! do you know what kind of light outlets you used
    PairADice, the only ones I remember are the port and starboard lights. They were manufactured by Attwood.
    Jerry
  • Awesome, thanks!!
  • Cableguy GregCableguy Greg ✭✭✭✭✭
    I used the Attwood LED lights on my 232 as well. They worked great!
  • JoeStangJoeStang ✭✭✭✭
    Just FYI Rinker went to LED docking lights on the 2014 276 (and I'm sure other models), so they could be a source for a pulg & play if the housing size is the same as your oem.
    2013 276 Cuddy ~ 350 MAG / B3
  • Black_DiamondBlack_Diamond ✭✭✭✭✭
    I did this on mine, made some SS spacers as the hole was wrong to mount up my new lights. I can look up what I bought if you want and the spacer drawing. I think they were Hella lights.
  • I was looking at these...
    defender marine is about 20 minutes from me.. so hopefully they will work
  • I replaced my front red & green navigation lights, anchor light and transom light with LEDs. I made sure I got the 3 mile lights LEDs on the anchor and transom lights. It may be overkill but I wanted to be seen while on the hook. It wasn't to expensive and easy to install. Search Amazon for good price.
    I have the same lights that Capt92ofd has. They work and look great!
  • Same.. Those are the ones I went with.. they are AWESOME!
