Water heater hoses from engine.
Hi,
I have a Attwood water heater model EHM6, I would like to find out where are the hoses from the engine( 5.0) plugs in the heater, the hose that come in from the recirculating pump in the front housing should go where ? Looking at the picture does it goes where the red circle is on the heater barb or the the other one in yellow
Thanks
See pictures below
Frenchship....I have a 310 FV w/ twin FWC 5.0's...not sure on the brand but my water heater (probably Attwood) is connected to the loop on my starboard engine. I believe there is connector coming out of the engine (hot coolant) which circulates the water heater and then back to the heat exchanger. I don't have any pictures, but I will be at my boat this weekend and can snap a few....hope that helps.
I believe either engine could be connected to the water heater and as long as both hoses are connected to the same engine
2001 310 Fiesta Vee
T-5.0 FWC Mercs w/ B2
bmax
