Alcohol/ Electric stove Fuel
Just wondering what stove fuel type people use. I know you can get the "marine specific' alcohol stove fuel from the chandlery but its expensive, because its for a boat. And I know that in the States, denatured alcohol is recommended for use in stoves. But thats hard to find in Canada, and doing some research I see that using Methyl Hydrate or Ethanol is acceptable, but theres some disagreement as to the amount of heat produced by these fuels and the fact that they might produce more smoke. Just wondering if theres a consensus as to what fuel to use......particularly as it applies to us in Canada.....
Best Answer
Cableguy Greg Member Posts: 5,066 ✭✭✭✭✭
I also used denatured alcohol. I found my small quart sized can at Lowes.
Probably not an issue, but you may also want to look into the temperatures each alternative burns at ... some may be too low ... I know denatured alcohol already took too long to boil water ... not sure if too hot would be an issue as well ... doubt it ... but worth looking into.
On the other hand ... does anyone have the number of boats out there that use fuel onboard for cooking? I'm going to guess millions??? So now all of a sudden it's too dangerous?
I'd guess that only a tiny fraction of boats are equipped with liquid-fuel stoves, and only a tiny fraction of those stoves ever get used. I had one in my first boat. I used it once, and it scared me so much that I never used it again.
