Lost power to most accesories at once
Cozzi236Cozzi236 Member Posts: 2
Was out last night on my Captiva 236 BR and all the lights (docking, anchor, swim, bow, interior), the radio, and the horn all lost power at the same time. Any idea what it might be? Haven't checked the fuses but find it hard to believe they all blew at once. I've contacted the seller and Rinker but haven't heard from either as of yet.
  • aero3113aero3113 Member Posts: 9,759 ✭✭✭✭✭
    Check all of your grounds, there can be a common ground for all of them that might be corroded or broken.
  • Cozzi236Cozzi236 Member Posts: 2
    Thanks I'll check them out.
    ^+1
    And, there is a 50a breaker near your flame arrestor that may need resetting... Question is, why did it trip, if that is it?
    There is a fuse that runs all of that stuff on the wiring harness in the engine compartment. The 50A breaker is just for the engine. There is a separate inline fuse for the rest of the equipment. The other place to look is the large multipin connector that come from the engine to the helm. I hat my hot wire work itself out because the connector was jammed together.
