Remote oil filter hoses
Anybody know what the torque specs are on the remote oil hose flare nuts that go into the block adapter?
I replaced mine today but space was so tight that it was hard to get leverage to tighten the flare nuts.  I think I got them pretty snug, but I'm a little paranoid.
  • aero3113aero3113 Member Posts: 9,289 ✭✭✭✭✭
    When I did mine, I snugged them up pretty good. I was able to use wrenches on my 330 with room. A set of crows feet, an extension and ratchet will probably help you out.
    @aero3113 - I have absolutely no room for any tools besides a box wrench.  Almost no room to put any force on the wrench to tighten.  When I go back I'm going to look again and just make sure
    @skennelly with a crows foot you would be coming up along the line from below. With a long extension hopefully it will work.
  • YYZRCYYZRC Member Posts: 5,261 ✭✭✭✭✭
    Could you remove the bracket that holds the filter, attach the lines, and then reattach the bracket?
    @YYZRC I don't think that would be possible.  I seriously have bearly enough room to fit my hand in and then it's working by feel.  If I remove my water heater I might have more room...but really don't want to do that.
    @aero3113 I think I know what you are saying with the crows foot.  It would prevent the line from moving as I tighten the flare nut.
    I think being a marine mechanic is the worst job. Being an armchair marine mechanic is pretty great, though.
    edited April 2021
    @YYZRC yeah.  Everything beyond an oil change is usually a nightmare and I always go into the job with confidence that it won't take that long to do lol.  I'll never learn
  • TonyG13TonyG13 Member Posts: 1,356 ✭✭✭✭
    And you always buy the proper tools to do the job, then never use them again! That's how I do it! Admiral just asked yesterday what came from Amazon, and I said "just a tool for the boat." She rolled her eyes. :smile:
    Thanks for the education. Never knew what a crows foot was. Man would those have helped in some bad positions on my Rinker. Will be grabbing a set from harbor freight ASAP!
    @Liberty44140 , they’re one of those tools that come through for you. You try every wench you own then you remember you have a set of crows feet.
  • LaReaLaRea Member, Moderator Posts: 7,846 mod
    While you're at it, look up this little gem:  "Indexing ratcheting combination wrench"
    This 30-second video explains how it works.  Pay attention to what he does at the end, with the indexing joint unlocked.  When you need to run a bolt in or out in a tight space, it's really fast and easy.
    https://www.youtube.com/watch?v=HmVsHcRziNA
    edited April 2021
    @LaRea , it’s a cool design but wouldn’t work with a hose on the fitting.
    I changed these hoses out hoping they were the cause of an oil leak I had.  I always noticed it leaking directly in that area and the hose appeared to be oily.
    I had to somehow validate my work...so I rigged up a bench test for the old hoses.
    Essentially I blocked off one of the oil hose and submerged the hose in water and injected air from my air compressor into the other end.  And there I saw bubbles coming from the hose itself on one and from the crimp fitting on the other.  So both hoses were probably leaking.
    I feel pretty good...hoping for an oil leak free season.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,719 mod
    I got lucky.  My oil leak was fixed just by tightening the bolt that connects the remote to the motor.  Worked for both motors! :smile:  Thanks to someone on here that mentioned it earlier this year.  I tightened it the first weekend in March before my inauguration ride and it's been good since.
    Nice.  I'm launching next week.  True test to come.
    edited April 2021
    A couple of days before I went to launch last season I had one of the starboard side hoses fail. I couldn’t get OEM before launch so I had a set made by a local hydraulic shop. I used the lines all of last season. When the boat was out of the water in fall, I installed the OEM lines. I also replaced the O ring at the fitting and at the opposite side of the adapter. Both O rings were as brittle as can be. I did have a slight leak back there, I’m assuming from one or both of these O rings.
