Hatch override
Corral42
Member Posts: 63 ✭✭✭
Has anyone experienced a hatch override that will open but when you reverse polarity nothing happens? Switch at helm works but trying to understand what’s going on with the override.
https://rinkerboats.vanillacommunities.com/discussion/8162/how-to-open-the-engine-hatch-with-the-batteries-disconnected/p2
And here's the schematic for your 370:
If the normal Hatch switch could be operated, then the assumption is there would need to be two people there for someone to be closed in the Hatch ... one inside the Hatch, and one at the Helm where the switch is ... so that second person could always open the Hatch via the switch. If someone overrides, it's possible they are on the boat by themselves.
Also on the 260EC, the Hatch was heavy, but if you did a squat, you could probably open it ... although it would be pretty tight in there with the Hatch closed .... not sure if the Hatch could be closed with the override ... never checked that.
Rechargeable Inflating Paddle Board Electric Air Pump 16PSI with Built-in 6000mAh Li-on Battery,ISUP Pump for Inflatable SUP,Kayak,Tent with Inflation and Deflation Function https://www.amazon.com/dp/B0881FFSYW/ref=cm_sw_r_cp_api_glt_fabc_PRWNFPTGPYC3YXQ8S62N?_encoding=UTF8&psc=1
@Viggy to operate the hatch lift with batteries disconnected, plug the boat into shore power. Turn on the battery charger and turn all battery switches on. Hatch should operate normally.
Same with the house circuit (which operates the solenoids).
