Shower Sump Vent?
aero3113aero3113 Member Posts: 9,634 ✭✭✭✭✭
Is there supposed to be a vent on the sump box? When I winterized it last fall I noticed some antifreeze in the mid bilge. Turns out the float was stuck and it either leaked out the top seal or what I think is a vent? I can seal that hole off if it’s not used as a vent. I’m pretty sure it’s open, I should’ve stuck a wire through to make sure.
