Charging Problems
I have a 04 FV 270... last fall I noticed that the voltage meter wasn't showing 13 volts
while under way...Put the boat away for the winter...in the interim I had both
batteries replaced( one had a dead cell and only measures 8.6V)..I also took the alternator in and had it rebuilt..
new diodes and volt regulator...hooked it up today and volt meter on dash still showing
approx. 12 volts...have checked all wiring on alternator and batteries...anyone have any ideas before I pull
out the alternator again....
Thanks
Good luck, sir... I don't think you need it, though.. :-)
