Re install porthole window
lesles Member Posts: 24 ✭
I am re installing porthole window in 270. Vinyl foam backed walls are wet. I removed. Can window go in and new vinyl go in after
    I had the same issue. I left the vinyl walls up but pulled them away from the hull until a dry area could be found. Place a cup under it to form a tent and blew air for 24hrs. Bone dry and lightly spray, glued back down.
    I think you'll be happier if you wait on the window and set the new vinyl first. Much cleaner install.
    LG
  • lesles Member Posts: 24 ✭
    Yes I think that's true I had to remove it totally on starboard side since it was soaked and mould smell over time.
    I would never had known if I didn't take window out.
