2003 312 how do you..............
2003 312 new to me.
1) How do you access the anchor locker? Don't want to cause problems for myself trying to access on wrong area.
2) How do get the microwave out? And while I'm asking, the coffee maker also? I would like to access the 115 power behind them.
Thanks in advance. Shelby
2005 320 Twin 350 Mags MPI Bravo III Lake Cumberland, KY.
Best Answers
TonyWalker Member Posts: 744 ✭✭✭
If I remember correctly about the anchor locker, the mirror should pull off as I think it is stuck on with velcro. The there will be a "screw off" hatch that will allow you to either look in or get your arm in, not both.
The microwave as I remember it is secured to the compartment with screws. This is an item that was never planned for removal. -
MarkB Member Posts: 3,989 ✭✭✭✭✭
Your mirror in your cabin right at the front if the v berth should come off if you pull it. It's on Velcro. Open portal behind it and there you go.Boat Name: King Kong
luckydog Member Posts: 316 ✭✭✭
I don't know about the microwave but the winless access I had to do it on mine I have a 312 also hope this helps
Thanks. Shelby
I also had to remove the power panel to gain access to the microwave plug. I plugged a 6 receptacle power strip in where the microwave had been plugged in and ran the strip in front of the partition so I could have 115 volt power on starboard side of front berth. I mounted a flat screen on an articulating arm to the back side of the partition. Now I have power for it and the satellite receiver. Granddaughter is now happy.
Thanks luckydog for anchor locker picture.
Shelby
