Fresh water pump
I filled the fresh water tank to flush it, then turned on the fresh water pump. Seemed to work ok, but I found out that when the pump is on, water is spraying out of the city water inlet on the transom. Is there a check valve somewhere that I can service/replace to stop that from happening?
