Prop replacement question
Just ordered replacement prop set for our 232 Captiva w/ Bravo III. Can anyone tell me if the washers and nuts should be replaced with the new prop set?
Or can I use the old ones if they are not damaged?
@Russ - It is smart to pull off the props on the BIII if for nothing else than to regrease the shaft splines, that is recommended maintenance. Taking off the thrust washers is good too: clean and regrease. A gentle tap with a drift and it should come off, it is a slip fit on the shaft. Jusy don't goober up the tapered portion.
As for a fastener, if you want the true technical answer: never reuse a fastener. Once you properly torque it you actually stretch the fastener and it is never the same again. Then there is reality and practicality in non-critical applications. Nylock fasteners can be reused a few times, but eventually the nylon wears and it is smart to replace.
