How much water should be in boat after an hour?
2»
    GMSLITHOGMSLITHO Member Posts: 1,561 ✭✭✭✭
    If your new to boating have the marina take a look
    thrcaptiva276thrcaptiva276 Member Posts: 12
    Thank you all, driving better, we did not have water in the cockpit at all.  Only while beached bow in did the bilge come on.  It never came on under driving conditions.   While beached the bilge came on for 30-50 seconds every 10-15 minutes.   When I opened the hatch and inspected it looked like water was dripping under the pressure and waves right around/above the steering arm/drive shaft.
    Yep, that sounds like the transom assembly is leaking.  It will only get worse in time and corrode more things as well.  Definitely something you will want to get checked out and fixed.
    Thanks again everyone.  The captiva is out of the shop and dry dry dry!!!  Thanks again everyone for your input.
