Oil pressure high
Just bought my 2000 Rinker Captiva 232. It has a Mercruiser 350 MAP MPI with Bravo III outdrive.
The oil pressure gauge is reading maxed out. Not sure if it is the gauge or the Oil pressure sender at this point. Anyone ever have this issue and what did you do to fix it ?
I ordered and received the oil pressure sender (8M0068784) but not exactly seeing a perfect match for this on my engine to replace. My engine serial # is 0L363645. The parts guy assured me this is the correct part.
I thought I had the right one on the engine but it seems like it is some sort of water pressure sender instead so popped that one back in.
