Buying a 2008 280 EC - Advice
mvgvb
Member Posts: 46 ✭
Hi,
We are looking at a 2008 280 EC, with a single Penta 8.1Gi with ~520 hours. Boat has been used in fresh water, but we'll be moving into salt water.
Just had the survey completed, some moisture in the transom and blistering on the hull (thinking mostly cosmetic), are these common issues? A couple other more minor fixes needed to the windlass, new spark plugs, etc. Engine appears to be in good condition, along with the interior being well maintained and in good shape.
Firs time boat buyers, would appreciate any advice, common issues, or things to be aware of.
Check compression and be sure to operate all systems to their fullest on the sea trial.
There is 2 of us on here who are very active on the forum if you have any questions.
How big of a deal are the hull blistering and moisture/softness in the transom? Surveyor seemed to think both could be fine for a few years, but that the blistering would affect resale value and the transom would likely need to be redone eventually. But they didn't open the transom up to confirm.
Thanks!
How long has the boat been in the water? Normally small blisters go away over the winter if the boat is laid up on land and re-appear after a couple of months in water and as long as they are small it would be OK. If they are large the bottom will need to be stripped and sealed.
The surveyor found high moisture readings in the transom but the soundings were good meaning the core is solid much like my boat. At some point you are going to have to find the source of the water intrusion and deal with it. If it is left too long the cost to repair will get larger. I am not trying to put you off buying but I would certainly be negotiating the price down to cover future expenses. I have a post on this subject.
The blisters were small, maybe 1/4" for the most part. Mostly located on hull bottom and transom. Surveyor recommended bottom painting over them as opposed to stripping.
Might be an older boat, but we are hoping to get at least ~5 good years out of it if possible (and ideally still have some remaining value). Does that change the equation on the cooling?
Old boat or new boat just do whatever you feel like doing and if it's worth it to you then go for it. All about you having a good experience rather than will the investment pay off, it's a boat not an investment for future retirement 🤑
