Water leaks at fuel cooler/pump
Need a little information on 2007 350 with dual 350 Mag motors  have a small leak from a cooler hose that goes to the fuel cooler/ pump on the side of the engine.  Hoses look to be a bit tight but thinking as retired tech I can handle the job.  Question is can it be done with the boat in the water?  Without the engine running the pumps in the I/O should not let water flow in correct ?
