2009 280ec 85 hours HELP ME (:
we bought it last year, it was always on shore power and the marine mechanic put in a FW cooling system, the engine hatch opened with extra charger and shore power, so we went to launch runs perfect, gauges work, we had well known mechanic with us, no one knows RINKER! just for a sea trial, we couldn't use any accessory or open engine hatch , even with shore power, surely a battery is dead? no lights in cabin no blower etc, so assuming One battery is good, alternator good ,starts beautiful, no power to dash buttons and or engine hatch to even check batteries, the engine and gauges and smart gauge works, we used the hatch override panel with a portable charger...nada. HOW DO WE GET IN THE ENGINE!! Im so frustrated. a few weeks ago plugged in at the place that put in FW system they had to use extra hatch charger but hatch opened. NOW nothing. HOW do we get in there? is this a fuse ? dead battery? switch? we are missing , tried everything we could think of. if we cant get in to hatch cannot fix!
As far as the hatch if you open the back swim deck compartment and unscrew the vent in the floor on the starboard side you then reach your hand in and you can pull the pin from the hatch lift allowing you to manually pick up the lid. This is a two person job and have something ready to hold the hatch open.
gosh we only have 80 hours on the whole boat! praying
On that not though @Sej1969 if you want me to stop by sometime on my way back and forth to help answer any questions in person I would be more than happy to.
On shore power do your AC powered appliances work such as stove, microwave, HVAC, outlets?
You are sure all the switches are set correctly in the cabin control panel and also no popped breakers at the battery switch panel? There could possibly be a bad breaker as well in the system, not hard to test but that may be a last resort or atleast towards the end of diagnostics.
How about at the battery selector panel by the transom door are all those breakers ok. There is two types of breakers on the battery selector panel if I recall correctly.
This isn't your panel but it shows the other style of breakers in the popped position shown by the yellow flags or whatever you want to call them.
https://images.app.goo.gl/DBSZu4WWLhAFRmyB8
It really seems like a bad cable from the battery if you are sure that house battery is good or maybe a bad selector switch at the panel by the transom door.
She is getting 6VDC on each house battery, which in series gives her 12VDC. The power isn't making it from the batteries to the switch in the battery panel. When the switch is placed into Emergency, it is combining the two battery circuits, which is giving the house side power from the starting side.
There seems to be a disconnect between the house batteries and Position #8 on the back of the switch. I believe some wiring tracing is in order. Here is the battery charging circuit. In one of the pictures that was sent to me it looked like the isolator was removed or moved to a different location on the boat.
So maybe the first step would be to check behind that battery panel for a lose wire or corrosion on the battery selector knob?
