Opinions on battery type/size
I need to replace the house batteries on my 2011 310, I think that I want to go with AGM batteries, I currently have 3 105 ah flooded batteries. Our marina has no shore power so we use solar to keep the batteries topped up from weekend to weekend, I have 4 x 20 watt solar panels mounted on the radar arch. What are the opinions on the best AGM battery to use? I'm also wondering if I should look at 2- 6 volt instead. Rolls/Surrette seems to have a high quality unit, does anybody have any experience with them? Do the AGM's work well with solar charging? We do have a generator and we anchor out all the time so we use a lot of battery power.
bmax
bmax
Penn Deka says that all the batteries should be the same chemistry - unless you are using two battery chargers which would be a bit complicated but doable, in my opinion. If flooded and AGMs were mixed I think that the AGMs would charge a lot faster than the flooded ones and the charger would shut-off - starving the two flooded starting batteries. Although your starting and house batteries may be own different circuits I believe the charger only reads them all as a group. I guess you have a decision to make whether to stay with flooded and replace your house batteries with flooded now then all your batteries when they go or "bite the bullet" now and go AGM for all of them. Having used AGMs I would never use flooded again. I had four series 31 AGMs in my last boat (2 starting and 2 house) and they were awesome. In particular the house batteries really outlasted - by a very wide margin - my friends' flooded house batteries. On our new boat I have 2 starting and 3 house Series 31 AGMs in parallel. I was thinking of using 4 house AGMs but when I calculated the output of three there was no need. Even two Series 31 AGMs wired "properly" in parallel are real beasts! Good Luck bmax. MT
