Arch Light replacement for 26QX
Bassman1282Bassman1282 Member Posts: 8 ✭
The light on my 2019 26QX arch busted off thanks to a low dock roof. Can’t find a replacement or a part number for the life of me. Not even the dealer I bought it from has been able to help. Thisight screws into the ski tow at the top with the plastic bushing for your rope below it. Anyone have a part number or a similar replacement that will screw in?
    Since you say it was knocked off from a low dock roof, are you referring to the all-around navigation light on top of the arch? (That's different from an arch light.)
    The two big nav lights manufacturers are Attwood and Perko.
    If you post some photos, it would be easier to help you identify what you may need.
  • Bassman1282Bassman1282 Member Posts: 8 ✭
    Yes I am referencing the all around navigation light. Unfortunately the thing broke off completely and went into the lake. I will see if I can find a pic from before it happened. Basically the nylon ski rope bushing slips over this metal piece which is welded to the tower. Then the light screws into this piece and sets on top of the bushing. The wires run through the welded metal piece to the light assembly.
    Here it is
    Maybe something like this?
    https://www.amazon.com/Perko-0455DP1CHR-All-Round-Light-2-Inch/dp/B005FCI5FU
    You'll need to do some measuring to see what might work, but like I said Perko and Attwood will probably make something that fits.
