2009 280ec 85 hours HELP ME (:
2»
    ok so i will bite.  WHY would someone want to rewire the boat for 6v batteries?  Seems to me like they added extra complexity for what benefit?
  • Cableguy GregCableguy Greg Member Posts: 5,051 ✭✭✭✭✭
    Longer run time on the house side.
  • Aqua_AuraAqua_Aura Member Posts: 2,681 ✭✭✭✭✭
    edited May 2021
    Never knew that. I'll have to research to satisfy my knowledge needs.
    Well that was a very easy search. I guess 6V has higher AH and when in series to get 12V they retain that AH rating. Two 6V deep cycle batteries is $270 each and have 230AH which is significantly higher than my 1 12V at I think 120AH
    Post edited by Aqua_Aura on
    We use golf cart batteries a lot in the RV world.
    That is a lot of weight in batteries for a 280EC.
  • GrahamuGrahamu Member Posts: 895 ✭✭✭
    I installed 4 6 volt golf cart batteries for my house bank
  • Dream_InnDream_Inn Member, Moderator Posts: 7,791 mod
    It is really not that uncommon for boats to use golf cart batteries for inverter banks of storage.  Tie them together, put an inverter on it, and then you have plenty of AC power without having to run the generator.  Some of these boats actually have separate outlets marked as off of the inverter. It actually works quite well.
  • YYZRCYYZRC Member Posts: 5,343 ✭✭✭✭✭
    Rinker is the perfect boat for that. You could repurpose one of the “it’s shore choice” on the panel for the inverter/house battery bank. Very little reworking and fully integrated.
    I had to do some reading to understand the pros and cons.  IMHO the cons outweigh the pros.  From what i read equivalent 6V vs 12 V setups will have the 6V setups weighing more and costing more.  The kicker for me was that if one battery goes out you are dead in the water.  if one of my 12v batteries goes out i can still work off of the other one.  Costs more, weighs more for minimal increase in AH.
    @davidbrooks not true if you lose one battery you are dead in the water. You move either the positive or negative cable to the 2 batteries that are connected in series and still working
    How do you figure out which battery is dead? Wouldn’t you need to load test to know for sure?
    edited May 2021
    @YYZRC, test each battery with a voltmeter, the bad one will show lower or no voltage
  • rasburyrasbury Member Posts: 8,654 ✭✭✭✭✭
    Can't you do the terminals by the battery switch with 12v and open the hatch? The motor works right, just no power to it? Guess I'm missing something...
    They tried and it didn't work
    Then through the table mounting, cut the blanket and pull the pin. Only way on a 270..can't pull the hinges..
    Come on now get caught up. It's thru the vent in the back storage area @rasbury we already went over that.
    How did I miss all this? Guess it's not laid out like a 270...or maybe I can get to it thru the vent. Never had to so will keep it in mind...
    I feel like the 270 should be close. The table was my first attempt and there was no way then I found the vent.
    @Grahamu yes that works when you have 4. But if you only have 2 6 v batteries and not 4 for two fully redundant banks then you only have 6 volts. I think you have a very workable solution. It is just more expensive and heavier. However from what i read is more durable. This has just been an interesting post to follow for me because it was a new spin on a old topic.
    Susan had four 6v batteries on the house side and two 6v batteries on the starting side of her boat. She ended up having 4 dead 6v batteries on the house side. If I had a bigger boat, like a 342 up to a 420, I would go the 6v battery route. With a 280EC, I will stick with my two 12V deep cycle batteries on the house and one starting battery.
