Dead Batteries and Engine Hatch Override not working
alaskanduck
Member Posts: 12 ✭
2018 Rinker 29QX. Stored at club outside. Just wen to launch and batteries completely dead (another story). Connected portable jump starter to override and nothing (switch battery switch on and off). I didn't connect backwards. Had to use it once last summer when batteries died and hatch started up immediately after connecting to posts. Tried two different portable starters with decent charge. I assume batteries are connected, the guy who winterized didn't disconnect them past two years.
Fuse? Possible to manually open? Dead in water until I can get to batteries.
Thanks, Shawn
Thanks, Shawn
In normal operation, there is no connection between the override posts and the boat's battery. A dead battery will not affect your ability to raise the hatch using the posts. If you're putting 12V on the posts and nothing happens, I'd suspect corroded pins in the connector on the bottom of the actuator. Or it could be that the actuator got seized up by putting the gears in tension.
Putting a trickle charger on the override posts will not charge the battery because there's no connection to the battery. In theory, you could charge the battery by pressing and holding the helm switch, but there's a 50% chance you'd get the polarity wrong.
(Larger boats use a different hatch circuit with diodes and relays, and I'm pretty sure that circuit will not charge the battery either.)
I'll probably tow it to the dealer that sold me boat but they said I've tried everything they're aware of.
Yes, there has to be some way to manually release the actuator by pulling the pin at the top. I'm not familiar with that boat, but it's usually reached via a table base, or a vent or other removable panel.
I mentioned binding the actuator. In some cases, if you hold the switch in the "down" position too long, it puts the actuator in tension. That can bind the gears and lock the actuator from moving. If that's what happened, once you release tension by pulling the pin, it will release the gears.
I'm assuming the club member who winterized for me last November opened and closed the engine hatch. Something happened since then. I have no idea where the actuator is located in the engine compartment and where to look for panel but I'll give it a shot.
Say, if the override posts don't connect to battery, where is the ~5 amps the charger says it's putting out going? The portable jump starter? But it's fully charged. Just wondering. FYI when I attached charge to posts no amps until I connected jump starter and turned it on, I assumed charge was going to the battery. It's an ancient Sears charger from neighbor that you plug in, connect, and one guage for amps.
Thanks for all your help.
Shawn
