Lightning
aero3113aero3113 Member Posts: 9,530 ✭✭✭✭✭
I was just wondering, is it better to stay plugged in at the dock when a storm comes through or unplugged? I know you can’t be there every time a storm comes through, but when you are do you stay plugged in or not?
    I can give you advice from the RV world. Whenever there was an electrical storm close I always disconnected from shore power. If needed I ran the generator. I didn't like the chance of a surge doing serious electrical damage.
    I never unplug. Dock post has breakers and my inlet has breakers. Curious on other comments though, maybe I should!
    I never bothered. It shouldn't affect whether or not you get a direct strike. And if a surge is going to happen it'll happen whether you're there or not. So why worry while you're there? We had enough stick boats with nice tall aluminum masts 2 rows down from us that I never worried much.
  • Dutch320Dutch320 Member Posts: 83 ✭✭
    You could always use a surge protector for a little piece of mind. Never gave this any consideration until I read this post, now I have more work to do lol.
    • IanIan Member Posts: 2,973 ✭✭✭✭
      Plugged in you at least have a path to known earth that will sink to ground in part versus just to water, electricity takes the easiest path so unplugged it will find a way to earth somehow - give it one to take first versus through the hull an drives. Surge incoming on shore power should pop breakers but big enough it will damage anyway; nothing will stop a direct hit to your antenna or rail.
    • LaReaLaRea Member, Moderator Posts: 7,919 mod
      edited June 2021
      Personally, I don't unplug.  In the 23 years I've been in this marina, I've never heard of surge damage here, although I guess it could happen.
      But in my opinion, if a boat gets a direct strike, that wee little ground conductor in the shore power cord probably won't change the outcome.
        Dutch, we use those in the RV world. I use one at the main outlet and plug my RV into it.
        I saw quite a few for RVs, but most were exterior mount. I kinda liked this style because it could be mounted inside out of the weather. Surprised almost all of these on Amazon were geared towards RVs when we both have similar sensitive electronics on board.
        Yes a lot of RV owners have installed this inside
