2009 Rinker 360 Express 12 volt house wiring schematic
Rinker360Rinker360 Member Posts: 5
Everyone on this group. Just wanted to say hi. I am new on this group and this group came highly recommended. I am in search of a 12 volt wiring schematic for a 2009 350/360 Rinker. the positive side I have a voltage drop at my breaker panel on the 12 volt side trying to search. Thank u.
  • LaReaLaRea Member, Moderator Posts: 8,069 mod
    Hey, welcome to the forum!  Here's a set of wiring diagrams for a 2004 342.  Most of your boat will be the same, or similar.  We only have them for a few models, and I don't recall seeing any for an '09.
    So you're seeing low voltage on the DC meter at the cabin breaker panel?
  • Rinker360Rinker360 Member Posts: 5
    Yes ..  The lights flash then after it draws down then everything 12volt turns off . then after about 15 /20 seconds everything comes right back on.  I have 13.4 at the charger and the house Batteries. But only 11.4 at the 12volt panel. ???
    House 12V DC power goes from the house bank to the battery switch panel (usually in the cockpit), and from there to the breaker panel in the cabin.  Sounds like you might have a connection that is loose or corroded.
    At the panel or engine room?
    I'd suspect engine room or on the back of the cockpit battery switch panel.
    Sorry .. Where is the cockpit Battery switch panel? The House Battery switch?
    On my '07 boat, when you first walk onto the boat, there is a panel down near the floor that has battery switches and a bunch of circuit breakers.  That's the cockpit panel. I'm not 100% familiar with your boat, but the panel would have to be pretty close to the transom door.
    Yes .  mine is the same . Thank u
