Outdrive question
GMSLITHO
Member Posts: 1,602 ✭✭✭✭
my brothers boat has a alpha drive .The drive will go up and down fine ,but when it is raised all the way up in the trailer mode it gets stuck there,He has to release some pressure by removing one of the hydraulic lines then the drive will drop down a inch or two ,put the line back on and it will move up and down fine
They took it to the shop for a service over the winter, told the mechanic to address the issue and was reported the resevrior was low. I've yet to hear if that took care of it as he's not launched this year but i dont know he's moved it out the garage a few times
Also it's pretty easy to remove arms to replace seals/o rings, clean everything then re assemble with all fresh fluid. Make sure it's all smooth and clean.
When it's sticks I'm assuming you can hear the pump trying to engage?
