Mag 350 mpi power steering pump
skennelly
Member Posts: 2,196 ✭✭✭✭
Lot's of noise on my engine. Took off the belt and the noise went away...so I started tugging on pulley's. The only pulley that has play in it is the power steering. I guess that means I need to replace the entire pump right?
Suggestions on where to source a new pump? A little research says it's the same pump as a GM truck you just have to swap the reservoir and pressure regulator?
Thoughts?
Thoughts?
Maybe he can chime in with what part number he used.
