Safety issue with bow thruster
I had an issue with my bow thruster on the weekend that I wanted to share with everyone. We were backing into our slip and to control the front end I went to bump the bow thruster on and the solenoid fused closed and I could not turn it off. We were able to tie off the stern so it would stay put but then the fun began to try to shut off the thruster. I am assuming that this was a factory install but am not sure. There is no battery shut of switch and no safety breaker so I was running around the boat to find a 1/2 inch wrench and pull the neg battery terminal. Sounds easy but in a panic situation that 1/2 wrench was hard to find . As I pulled my senses together and went below with the wrench I could here the motor slowing down as the battery was loosing it's power .Of coarse the battery box cover would not come off. I will be installing a shut off but wanted to share this with the group so that everyone could check their system for a proper shut off.
Did you find a replacement for the solenoid? I'm due for a new thruster battery soon, so I wonder if I should replace my solenoid and maybe install a breaker/shutoff switch.
Thanks for making us all aware. I know I have a battery switch down under the v-berth (which is not convenient, but is there if needed).
But maybe I'll install a remote battery switch. This one from Blue Sea Systems sells for $165. At 12 volts, it handles 1000 amps for 30 seconds, and 400 amps for 5 minutes. I think my boat has a battery switch under the v-berth next to the battery (like @Dream_Inn mentioned), so this device could probably be a drop-in replacement.
https://www.amazon.com/Blue-Sea-Systems-7700-Battery/dp/B0016HRUPE
https://blog.side-power.com/en/onboard-safety-why-you-should-have-an-automatic-main-switch
